300w amplifier easy way
hi guys i search the easy way to build a 300w amplifier...
I have a subwoofer 300W with 4 ohm impedance...
I discover the driver audio LME49830 is the answer....
My question is : which mosfet could I use ?
is it the best solution ? have you other ideas?
thank a lot..🙂
may we know the subwoofer too?
it is likely -but indeed i can be wrong- but the 300 watts are just a sticker,
it may hapen that You do not need more than 100 watts or less to make it explode.
Specialy if it was ment for car use.
p.s.: i'm not mean, i would just like to save you from the trouble of building a big 300 watt amp only to find out that the 300 "what" rated woofer will not handle than a few handfull..
Is that 300W rating continuous, or music programme, or peak, or some other?
It may suit an amplifier from as little as 100W if that was a peak rating.
Or it may suit a 600W amplifier if that was a continuous rating AND you ensure the amplifier NEVER sends a clipped signal to the driver.
You need to know what the 300W rating means.
thank a lot..🙂
dean95,
You found the right answer.
You might want to use a pair of ACD101NDD and ACD103PDD lateral mosfets.
See:
http://www.diyaudio.com/forums/soli...amplifier-based-lme49830-lateral-mosfets.html
It looks really, really good, to me.
Tom
