Yves,
I like pentode driver for 300B too! 6BW7 at 170V/10mA sounds nice.
But if we are to be KISS, do we really need the fixed bias windings and network? Why not be more KISS with a cathode resistor?
And then you can use MKP capacitors in the Western Electric network for better sound!
With ANSAR CPA series you can get good sound for a low enough price -
http://www.cricklewoodelectronics.com/Cricklewood/home.php?cat=155
Yves,
<snip>
<snip>
Should be mu + 1 since the noise injection point is the cathode, in practice I've found the value is not that critical.. I have used this with considerable success in a couple of simpler designs where the improved psrr was worthwhile, that said there is nothing like no cathode bypass capacitor and for this reason I still prefer fixed bias. My best sounding designs IMHO and by general consensus all use fixed bias - you are swapping slightly more power supply complexity for a simpler signal circuit path IMHO..
YMMV and just my
Hi Rod,
It's true that cathode bias could made things more KISS, but, as kevinkr, I really dislike any kind of bypass capacitor at so critical location.
"Fixed bias forever"😀
Yves.
Yves.
Salut Yves,
The cathode capacitor must be best quality MKP, for sure. Certainly no electrolytic, however fancy.
With fixed bias, you still have capacitors in the signal path - C2 in this case. This is the 300B input (grid) network current, too - I would say this is even more critical than cathode current! Noise from the fixed bias components, like D3 will also be injected here.
The B+ regulation looks interesting -
How does the 350V regulator sound, compared to using a choke-input power supply?
You're welcome 🙂planet10 said:Thanx for another interesting amp.
Salut Yves,
Mmmh, yes, zeners are noisy and it's why C2 is here !
However, at this point (bottom of the grid leak resistor), noise should not be a real problem.
The shunt regulator (D3 + Q1) is supposed having the capacity to absorb possible 300B grid current while maintaining stable voltage accross it.
Can't tell ! ! I never used choke filtered supplies since rugged silicon diodes and decent litycs capacitors were indroduced (thanks to SMPS requirements). . . some decades ago 😎
But, should a power suply "sound" ?
Probably it does cos in SE design signal has to pass thru it and the tube before reaching the OPT primary.
My goal was to keep PSU internal impedance low (says 10% of the Rp of the 300B) across the whole audio range.
I've tried to do "something else" and it seems to my ears that this thingy does not sound like a typical 300B SE.
This was the callenge I wanted to fullfill, sorry if this lent me to some heretical approach 😉
Must I add that I'm not a pure SE designs lover ?
Anyways, I had pleasure building as well as listening that.
Yves.
Salut Yves,
Tell us about the output transformer - was it the quality you used at ETF2009? With success!
The design of that transformer would be interesting to see.
Short before lunch . . .Salut Yves,
Do we meet ? Refresh my brain please !
I like to claim that I've built this amp ONLY to check the OPT !
Indeed, the ETF09 shotout was just the pretext to do something using those legendary triodes 😀
Yves.
What is F .315 in your PS schematic? Do you have a part # for it?
Also you may consider a larger ultrapath cap C1 ?
As said before C1 is not Utrapath and can't be because the cathode of the 300B is (almost) grounded.. . .
C1 is just here to reduce PSU impedance at hi end.
Probably higher value won't hurt if this does not disturb the serie regulator.
Guys, all your remarks urge me to bring to amp back on the bench for further tests 😀
I'll consider that while taking a nap 😎
Yves.
Yves,
I like Heretical design approaches, so I am a fan of Dissident Audio for designs like PC900 phono, DIY curve tracer, and of course DIY OPT.
I did not show for ETF2009, but found some Shootout results:
European Triode Festival - ETF2009 Shootout
Vraiment, il est remarquable de battre Partridge OPT à un concours - félicitations!!
- Tubes / Valves
- 300B SE amp: One more one
