Have been reading a lot of good reviews about Peerless TC9FD as a mid and about how the voicing is perfect and response is flat .
I am interested in a 3 way with TC9FD as a mid with a minimum of 8-10 or at the max a 12 inch woofer in a relatively small enclosure . Can some one point out any plans or builds which I might have missed ?
I did read a 5.5 inch tangband sub build , but the goal is to have an all rounder with a decent spec woofer and a tweeter implementation . The target cost would be under 300 USD for the drivers .
I am not good with speakers and crossover design so I am at this point of time looking for open source builds .
Any suggestions ?
Any suggestions ?
If you go that way, consider some FaitalPro drivers too. I find them to be as good or better in the FR, but with higher power handling.
I've not run across many such builds unfortunately. The TC9 has been popular as a wideband, but speaking under correction, it hasn't been as extensively used as a midrange in projects. One of the few I know about is this one, though not quite what you're looking for. Kierkegaard Still, it should be an easy enough driver to work with as a midrange, at least as far as FR goes.
I build this a while ago, little mtm, meant to be used from 150hz up. When you place it on good woofer, it will surprise you with an amazing sound. I think using two of tc9fd gives you better power handling, and close placement of midranges and the tweeter gives you coherent sound with minimized floor bounce.
MTM with TC9fd
MTM with TC9fd
Faital Pro are costly and not easily avaliable in my country .. As i had mentioned the cost of drivers should not exceed 300 USD . I am looking at building a speaker like wharfedale evo4.2 .
I am not too particular about TC9 .. I am leaning on to it since I have a good feeling about VIFA drivers for voice .I've not run across many such builds unfortunately. The TC9 has been popular as a wideband, but speaking under correction, it hasn't been as extensively used as a midrange in projects. One of the few I know about is this one, though not quite what you're looking for. Kierkegaard Still, it should be an easy enough driver to work with as a midrange, at least as far as FR goes.
The speaker looks good . How does it sound ?I did 3way with TC9 as midrange a couple of years ago.
LSM :: Pkaudio
Yes I did read up . The Nola clones need a sub i figured . I am looking for a 2 way build .I build this a while ago, little mtm, meant to be used from 150hz up. When you place it on good woofer, it will surprise you with an amazing sound. I think using two of tc9fd gives you better power handling, and close placement of midranges and the tweeter gives you coherent sound with minimized floor bounce.
MTM with TC9fd
Yes , Saw the build . That is a nice speaker . I have mentioned the same in my first post . It uses a 5.5 inch sub woofer . I am looking for a min 8-10 inch woofer .
Any builds with soft dome midranges which are good ?
Secunda - JustDIYIt !
Not TC9 and not a small enclosure. You did put some very specific demands though.
yugaaa you are totally contradicting yourself:
Yes I did read up . The Nola clones need a sub i figured . I am looking for a 2 way build.
3 way with TC9FD as mid -suggestions.
http://sbacoustics.com/wp-content/uploads/2020/02/8in-SB20PFCR30-4-1.pdf
http://sbacoustics.com/wp-content/uploads/2020/02/8in-SB20PFCR30-8-1.pdf
These SB 8 inch woofers are just about $42 US each. I have the smaller 6 inch version. A very good woofer in this price range; I don't know of many others that would have this much good performance in this price range.
I have been happy with the Vifa/Tymphany/Peerless line of less expensive tweeters also.
Vifa XT25BG60-04 Vifa Ring Dome Tweeter - Double Magnet - 4 ohm
This tweeter is hard to beat in the price range; many great reviews here and elsewhere.
- 3 way with TC9FD as mid -suggestions
