2x Hawthorn Audio 15" Augies and 2x Subwoofer Amps
Part of my clear out. I am selling above but the amps have been scratched up a fair bit. I could upload a lot of pics but I would want these collected from Reading so why not pop down and have a look. Just tested, used for less than a year, I went through a lot of gear chasing rainbows a few years ago, I dont do music anymore. The drivers have been covered with sound deadening as these are designed to be open baffle and talks with Darryl from Hawthorn determined it was very benificial. These are priced to sell cheap at £200 for the lot due to condition but are in excellent working order and hardley broke in. These drivers and sub amps open baffle produced the best bass I have ever heard, unfortunately I hated the tweeter that Hawthorn used and I just couldnt listen to the system. I did try using the subs with my bastadised Townsend Glastenburry's but Im not a designer and I couldnt get the system to gel so I moved on and kept this for a day that I now know is NEVER going to happen.
Sorry I forgot to say I cant remember the sub amp make but I am searching now. It was something like xyz. Will update.
They are XTZ Sub Amp 1's.
300w into 4
400w into 2
Variable control from 40Hz to 250Hz provides (-
3dB) optimum setting of subwoofer crossover
frequency to match crossover frequency of Home
Theatre components.
EQ 1: Increases 7dB @ 25Hz
EQ2: Increases 7dB @ 50Hz
The last one i could find sold for £175 with marks on AOS
https://theartofsound.net/forum/showthread.php?64227-Xtz-sub-amp-1
