2SK216/2SJ79 Spice models
Joined 2002
Does anyone have Spice models for the 2SK216 and 2SJ79 MOSFET devices.
Is there any generic low power mosfet Spice data that I can use in low power circuits. 100V, 2 amp devices.
In addition is there any Spice data available for 2SK170/2SJ74 ?
What are the closest Toshiba equivalent devices?
Does Hitachi give spice data for their transistors? I have not been able to find them.
Thanks.
Spice models
*SRC=2SJ76;QSJ76;MOSFETs P;Gen. Purpose;140V 500mA
.MODEL QSJ76 PMOS (LEVEL=1 VTO=-15 KP=122N GAMMA=18.6
+ PHI=.75 LAMBDA=1.48M RD=.84 RS=.84 IS=250F PB=.8 MJ=.46
+ CBD=444P CBS=533P CGSO=384N CGDO=320N CGBO=346N)
* -- Assumes default L=100U W=100U --
* 140 Volt .5 Amp 6 ohm Enh-Mode P-Channel MOSFET 07-28-1995
* 2SJ76, TOSHIBA, 1993 JAPANESE FET MANUAL, P.16
*SRC=2SJ79;QSJ79;MOSFETs P;Gen. Purpose;200V 500mA
.MODEL QSJ79 PMOS (LEVEL=1 VTO=-15 KP=122N GAMMA=18.6
+ PHI=.75 LAMBDA=1.04M RD=.84 RS=.84 IS=250F PB=.8 MJ=.46
+ CBD=862P CBS=1.03N CGSO=57.6N CGDO=48N CGBO=1.09U)
* 200 Volt .5 Amp 6 ohm Enh-Mode P-Channel MOSFET 07-28-1995
* 2SJ79, TOSHIBA, 1993 JAPANESE FET MANUAL, P.16
*SRC=2SK213;QSK213;MOSFETs N;Gen. Purpose;140V 500mA
.MODEL QSK213 NMOS (LEVEL=1 VTO=15 KP=.16 GAMMA=18.6
+ CBD=560P CBS=672P CGSO=26.4N CGDO=22N CGBO=852N)
* 140 Volt .5 Amp 6 ohm Enh-Mode N-Channel MOSFET 07-28-1995
* 2SK213, TOSHIBA, 1993 JAPANESE FET MANUAL, P.38
*SRC=2SK216;QSK216;MOSFETs N;Gen. Purpose;200V 500mA
.MODEL QSK216 NMOS (LEVEL=1 VTO=15 KP=80M GAMMA=18.6
+ PHI=.75 LAMBDA=521U RD=.84 RS=.84 IS=250F PB=.8 MJ=.46
+ CBD=658P CBS=790P CGSO=26.4N CGDO=22N CGBO=852N)
* 200 Volt .5 Amp 6 ohm Enh-Mode N-Channel MOSFET 07-28-1995
* 2SK216, TOSHIBA, 1993 JAPANESE FET MANUAL, P.38
JFETS
http://www.diyaudio.com/forums/showthread.php?postid=210374#post210374
Thanks.
Thank you for the data Fred.
I did find the JFET data but forgot about it when I wrote the message. I wonder if I am going to meet our old friend Alzheimer....... I am not old enough to forget so easily !!
Thanks,
Ashok.
Re: Spice models
This model doesn't work in LTSpice. Feeding it Vgs 13V and it still doesn't conduct. WTF?!
Re: Spice models
JFETS
Has anyone tried to use the models posted above by Fred ?
The VTO values seem to be wrong at 15V !
From the datasheet, I would expect something nearer 0.4V.
Maybe VTO is supposed to be 0.15V ?
What about this one?
.MODEL 2SK216 NMOS (VTO=-56.0259M KP=20U L=2U W=10.3184M GAMMA=0 PHI=600M
+ LAMBDA=2.12826M CBD=1.80316N IS=10F CGSO=1.13517N CGDO=1.13517N TOX=0 NSUB=0
+ TPG=1 UO=600 RG=50 RDS=1MEG )
/Hugo
Complement:
.MODEL 2SJ79 PMOS (VTO=322.944M KP=20U L=2U W=3.50594M GAMMA=0 PHI=600M
+ LAMBDA=24.1203M RD=1.88227 CBD=1.6459N IS=10F CGSO=1.13517N CGDO=1.13517N
+ TOX=0 NSUB=0 TPG=1 UO=600 RG=50 RDS=1MEG )
/Hugo
/Hugo
Hugo,
Thanks.
Tried the 2SK216, and it gives IV curves quite close to the datasheet, except for the low Vds region where the Id roll-off isn't modelled. I guess this is a limitation of the MOSN spice model.
Also, I had to change the NSUB parameter to 1e15 before it would work.
Chris.
Netlist said:
Complement:
Netlist
Are you still using these same 2SK216 / SJ79 spice models?
Or is there any better updated version .....
But they seemed to be alright.
I use EWB Multisim9
I was thinking of using 2SK216 model
to test when using it as a replacement for the IRF610 in BOZ preamp.
When BOZ is used as voltage amplifier for SEWA.
I want to figure out optimal drain voltage = output
for best driving the SEWA MOSFET follower at full power.
See here in SEWA thread
SEWA - Seven Watt Amplifier - 2SK216 BOZ MOSFET Voltage amp
thanks
lineup
cs said:
Hugo,
Thanks.
Chris.
Netlist said:
I have the models in a library but never used them so I can't actually comment if they are reliable or not. I'm not that much of a spice guru. 🙂
Okay, I try these models.
From cs reply, it looks as they are alright.
... curves close to datasheet ...
I may have to change that NSUB value to something,
whatever that is 😕
But dont you think he means:
1E-15
1E15 is VERY far from 0
Re: Re: Freds Spice models 2SK216 and 2SJ79
I Tried these models for 2SK216 and 2SJ79 , and they seemed to be a long way off.
The threshold voltage of VTO=15 perhaps missed a decimal point?
The data sheet indicates values in the range 0.2 to 1v.
Also the transconductance parameter is apparently 300 times too small at 122n !!!! (for the 2SJ79) while the 2SK216 seems reasonable at 80m
From the data sheet curves, one gets 40mA at 1v so in arm wavy terms the tranconductance is 40mA/V^2 so the parameter should be KP=40m (and not KP=122n).
I simply typed over the VTO and KP values, and renamed the devices bob79 and bob216, as follows:
.MODEL bob79 PMOS (LEVEL=1 VTO=-.1 KP=40m GAMMA=18.6
.MODEL bob216 NMOS (LEVEL=1 VTO=.1 KP=60M GAMMA=18.6
Now my amplifier simulation produces a symettrical sine wave output!!
BTW I am trying to fix a 2000W amplifier for a friend, and attempting to simulate it and then improve the protection circuits, so next time it fails it doesn't take out 80% of the semiconductors on the PCB. !!!
I have never been able to get these to work with LTspice. Never had problems with the Bob cordell 2SK135/2SJ49 2SK1056/2SJ162 models. But these 216/79 models have me scratched my head.
here is the error log:
Warning: Multiple definitions of model "z8_2" Type: Diode
V3: both pins shorted together -- ignoring.
Error on line 49 : .model bob216 vdmos (nchan vto=.1 lambda=521u kp=60u gamma=18.6 phi=.75 rd=.84 rs=.84 is=250f pb=.8 mj=.46
Unrecognized parameter "gamma" - ignored
Unrecognized parameter "pb" - ignored
Unrecognized parameter "mj" - ignored
WARNING: Node UNCONNECTED_PIN1 is floating.
WARNING: Node UNCONNECTED_PIN2 is floating.
WARNING: Node UNCONNECTED_PIN3 is floating.
WARNING: Less than two connections to node UNCONNECTED_PIN0. This node is used by M2.
WARNING: Less than two connections to node UNCONNECTED_PIN2. This node is used by M2.
Singular matrix: Check node unconnected_pin0
Any insight?
