2SJ79, 2SK216 substitutes
If you can get these, you'll not need to substitute....
http://www.renesas.com/fmwk.jsp?cnt...ower_mosfets_for_amplifier/power_mos_gen_amp/
Substituting a lateral MOS-FET (the types you mentioned are laterals) with a vertical is not that simple in many cases, and it's not a drop in.
The vertical IRF's need higher gate-source voltage to turn on, and they have substancially higher Cgd.
And I believe Charles Hansen would point out that the laterals do sound better...
Also, if I recall correctly, the pinout is different...:bawling:
What do you need to build or repair? A schematic would be useful to help.
If you do not need the high dissipation and voltage rating of the 2S.... types, you could try to use e.g. the small ZVN3310 / ZVP3310 from Zetex. They have comparable Cgd and transconductance, and gate threshold voltage is also lower than the IRF's.
Tino
hmmm
thanks for replyes.... i can't find them in local stores in my country (RS, Burklin, Digikey also don't have them).... Farnell has them but I have a minimum order of 50Euro's.... so it is a problem - if I can find them somwhere I would by them on reasonable terms..... suggestions....?
sch is like in post 14 or 16 of this thread - something like this with right parts...... (sch's are not completely checked - especially sch in post 14)
http://www.diyaudio.com/forums/showthread.php?s=&threadid=65298&pagenumber=2
Jean-Marc P said:
Sunny,
2SK216 and 2SJ79 (200V) : http://www.borbelyaudio.com/audiophile_components.asp (Germany)
2SK214 and 2SJ77 (160V) : http://www.selectronic.fr/ (France)
Jean-Marc.
borbely has also minimum order of 50 euro.... will see about selectronic....thnx
Ouroboros said:
The BUZ900 (N-ch) and BUZ905 (P-ch) are lateral power FETs for audio.
The Magnatek website has the data, and they are available from RS-components in the UK (But not from Farnell as far as I know).
hmmm ... this might be nice... will see the datasheets....
any other suggestions about 2sk216 and 2sj79????
WALTER BURKHARD said:
Take this there are in Germany or how many do you need ???
regards Walter
http://www.heho-elektronik.de/
Will see there also - I need 4 pieces of 2sj79 and 4 pieces of 2sk216.... i have contacted the guy from www.bdent.com - they say that they have them and that i can pay via VIsa.... will see the other links that all of You kindly supplied and after that I will decide where to buy (Supplier must have Visa payment method and also have the parts I need j79 and k216 😀)
edit: i just saw that on heho site they have written "Lieferung nur innerhalb Deutschlands." - to bad.......
rpapps said:
This company has 2SJ79 for AUD$5.65.
Email them for details and shipping costs.
enquiries@wescomponents.com
Cheers
Rob
Will try to find their home page to look around - thnx for Your information - it is a good price for them ...will se about the terms and conditions.......🙂 😀
all of You are very kind and helpfull... i must thank You ..... whne You have limited resources You have to look on everything and it is almost an art to get a good sound out of the thing You diy..... (don't get me wrong I am not an artist 😀)
Hi all,
I was looking for such thread, replacement of 2sk216 & 2sj79 with other transistors. I have denon poa-2800 which I didn't complete still many months from now, and I found out there are drivers 2sk215 & 2sj78, which is very difficult to find them here.
What do you think, can irf610 and irf9610 or irf540 and irf9540 can replace them at least just to try it if it works?? In case I don't have schema for this amp, I found out that, drivers 2sa1306 and 2sc3298 are connected with mosfets drivers.
Any help is appreciated.
thanks
