thnx Netlist.....it was needed
btw: how did You pull out from that list other data than Is, Bf and Tf......
🙂 thanks
I have parameters for the Generic model so changing a few numbers is no big deal.
Don't assume this model to be very accurate though.
This is Generic NPN:
.MODEL $GENERIC_N NPN (IS=5P BF=200 NF=1.2 VAF=100 IKF=100M ISE=2P BR=2 IKR=35
+ ISC=10F RE=500M RC=1M CJE=40P VJE=700M MJE=500M CJC=30P VJC=700M MJC=500M
+ TF=400P XTF=500M VTF=10 ITF=10M TR=200N )
/Hugo
/Hugo
netlist- thnx....
please tell me are parameters for the pnp the same as npn for generic model.....and also where to find generic models for other components (mos, fet, diodes and so on).....
best regards
sunny
best regards
sunny
I believe that every spice program has a set of basic or 'Generic' components build in. I know Microcap has, what are you using?
/Hugo
/Hugo
i ma using old EWB v5.12 proffesional....i have found that it has "ideal" component inside every type of the part and that is what i should adjust to have component that i need - right?!
regards
sunny
regards
sunny
- 2sc3423 spice model
