2sa1306-2sc3298 replacement equivalents?
Im repairing a QSC mx3000a power amplifier, the toshiba driver transistors 2sa1306 and 2sc3298 are no longer available, I have found these onsemi transistors which I think should work mje15034g and mje15035g other than requiring isolation when mounting will these work ok?
I have also replaced the main output devices with onsemi mjl1302 and mjl3281. Tia
