Hi guys!
I was looking for excellent, neutral sound, TO-92 small signal transistors and after having looked around in the forum i came across this pair here.
Appereantly they are better than the classic Toshiba 2SC2240 and its complementary (I had a chance to use them in comparison with others and decided i didn't fully liked their character).
Anyways, i have the A1016/C2362 on my hand.
Consulting the datasheet it seems that these two are PNP/NPN respectively *BUT* after have ran a simple test (with the diode check and a simple transistor tester on these cheap multimiters) i found them to be both PNP!
Am I missing something or there is a problem with my parts (maybe fake?!)
Thank you guys for the attention.
Post a pic, of the front.
They are good, but it also depends on the application, If its for phono, the toshibas are better.
Hi, i will post a pic of the front later on as i don't have a camera with me right now.
They look normal to me though...meaning nothing wierd on the front...i guess...but they are both PNPs! (in case do you have a reliable source on Europe?)
The application in on a phono stage but not as active gain nor cascode but currently on a nackamici current mirror configuration's style driving an outputy diamond buffer stage.
I am sure that there is not much difference on that position, but i would like to have a more suitable transistor than the current BC557/547.
Do you have a better suggestion in case?
Thank you for the attention.
They are good Japanese transistors.
Are you sure you did use correct PINS 1,2,3 .. when you did test?
.. 2SA =PNP goes in pair with .. 2SC =NPN
.. 2SB =PNP goes in pair with .. 2SD =NPN
for exampe, 2SA970 is the PNP for 2SC2240 NPN
well...not sure, but i have followed the datasheet.
the pin out i have considering, facing the round face of the transistor (fron view) from left to the right is
B C E
i don't know if i am mistaken or not.
the 2SA2240 and 2SC970 are fine, pin out speaking.
B C E
Hi ! Stefanoo
I use these Tr fo my amp and Volt Regu,and think these Tr are good,too.
the pin are both
E C B
datasheet sample is
http://www.audiolabga.com/pdf/2SA1016.pdf
P.S
I like 2SA1016K/2SC2362K ,they are hi voltage .
the pin are both
E C B
datasheet sample is
P.S
Flat side forward is how the devices are drawn on the datasheets, but non-techies in general have not been taught basic drawing rules.
Rotel has been designing with the duo for +15 years, the Sanyo devices might very well become obsolete in the near future, the moment they become trendy parts in the DIY scene.
Amusing.
Amusing.
- 2sa1016/2sc2362
