26 or 71A
Try this:
Output Transformer Type
This may be the acme of stupid questions and may not even be able to be answered here. But I'm gonna try. As I posted earlier, I'm building a 26/71A amplifier. I'll drive the 71A with a 26 or I may drive the 26 with the 71A. So, the question is: What output transformer should I be looking for as far as the primary winding? Secondary will of course be 8 ohm. 2,000, 5,000, etc...
BTW, unlike you guys, I don't know a lot about electronics. I definitely couldn't design an amp.
as friendly advise i will not build a DHT/DHT at first you will have to fight with sensible filament supply , microphony , and in need of of high gain preamp or 1:8 transformer input .
i can assure you that with a much simple Spud amp with E55L or 6EP5 you will get the same result and no needs of fancy power supply CCS or interstage.
i have both SE one E55L SPud and one 46/71A SET ( 2watts vs 0.8watts)
...stupid questions ... drive the 71A with a 26 or I may drive the 26 with the 71A. ...What output transformer...
Not stupid. Ignorant. Ignorance can be cured.
Read the datasheets!!!
http://www.mif.pg.gda.pl/homepages/frank/sheets/127/2/26.pdf
http://www.mif.pg.gda.pl/homepages/frank/sheets/127/7/71A.pdf
'26 is clearly specified as "RF and AF stages" meaning small-signal.
'71 is said to be "power amplifier".
And happy working conditions for '71 are right in the datasheet.
Note that '26 and '71 need very different filament supplies.
