I am collecting parts for building a 832 PP amp based on this audio diy
But I have trouble finding a 230V primary to 200VAC secondary power transformer. Heaters are 6,3V but I can find a second transformer for this if necessary.
Lundahl and Plitron supply 220V units but they are on the expensive side and require some reduction resistor or other solution. I have found a Edcor 8000K output transformer, and wonder if I should call them to hear if they have something not listed or custom for a reasonable price.
I have been through just about everything, but hope some of you guys can help. 😕
Do you have access to transformers with higher ratio (say 230V : 275V) ? You could use one and simply turn it around.
If you want a torroidal transformer, look at the 220 volt secondary ones at Hammond Mfg. - Toroid Power Transformer - (182 Series) .
By the way, I have one of those amps (see my avatar and search for some photos in the post pictures thread) and really like it.
Ah yes, I´ve seen your project kuroguy; inspiring!
There is not much current over the B+ so it might be OK to reduce 220v with just a resistor of two watt. That would open up my options a bit.
But right now I am thinking of using the XPWR088. Because I like the classic style. It has secondaries of 340V at 400mA, 200V at 200mA, 12.6V (6.3-0-6.3) at 5A and 10V at 5A. I´m thinking of using the 200v for two B+ es. With all four tubes I hope to draw about 0.100mA. And then the 2 x 6,3 for heaters have plenty of power. The others will not be used.
