Hi any one help me for operates AC devices from car battery for etc. mobile charger and dvd player or small tv
The device is called an inverter. Generally they are used only as a last resort because they are noisy (electrically).
I only found the 12Vdc-120Vac power inverter schematic.
http://www.i4at.org/lib2/inverter.htm
Change the secondary winding maybe obtain the voltage of 230v.
I never try this circuit before.
Crazy-Stereo said:I only found the 12Vdc-120Vac power inverter schematic.
Thanks man but i wants a high frequecy's osc because of thats are always smaller than the lo (50Hz) freq. osc and i only needs just 230v 200mAmp so if you can help me please
I've try to search the (higer osc frequency) inverter circuit but could't get it. I have no idea with this circuit. You may need other members from this forum for help.
An inverter typically generates a square wave or a sine wave at the same frequency as mains power in your area (50-60Hz). It has to use that frequency because that's what the transformer in the DVD player or TV was designed for. Higher frequencies driven directly into the transformer won't work. For example, if you drive a 20kHz square wave into the 50Hz transformer, very little power will be produced at the output of the transformer (not enough to run the device). The inductance required to run on 50Hz is too high of an impedance to the higher frequencies. If you want to use high frequencies to drive the transformer, you'd have to modulate them. This would be much more difficult to do.
I hate to say it, but this sort of thing is much better to buy than make, the parts alone would likely cost more than the purchase price of a small inverter.
i dunno what u got,new gen inverters are dammn quite.
a mosfet based inverter is silent.use this thing with inverter transformer.
http://sound.westhost.com/project89.htm
change rt and ct appropriately to toget 50hz
1 - Buy a powerplate amp
2 - Build a 50Hz oscillator
3 - Use a transformer (mains) in reverse at the powerplate output to get your 50Hz 230V.
You realise that you are wasting probably 100watts or more to run a 5W device?
Jan Didden
Jan Didden
janneman said:1 - Buy a powerplate amp
Jan Didden
this post is misleading as well as useless and serves no purpose.
- General Interest
- Car Audio
- 230v-AC devices operates from car battery
