I designed this 2 way speaker with the 6" Faital 6FE100 and the ScanSpeak D2606, it looks pretty good to me, but do you have some suggestion?
I will use this speaker in a tower mostly for Home Theather, it's good?
Thank you very much🙂
Should you feel that it was not adequate, despite the fact that it has been explained on numerous occasions how to properly perform simulations, then your approach is absolutely in order.
To me it only seems to need some crossover optimization when it is built (as any design does), but it should work as it is.
It's my second design, so i still learning, could you explain what's wrong or what would you change? What can I search for simulations?Should you feel that it was not adequate, despite the fact that it has been explained on numerous occasions how to properly perform simulations, then your approach is absolutely in order.
Like a L-pad to attenuate the tweeter? What other optimizations should I do if necessary?To me it only seems to need some crossover optimization when it is built (as any design does), but it should work as it is.
