2 way crossover for sound bar
Here's a useful calculator to start you on your way. Speaker Crossover Calculators by V-Cap
I suggest wiring the two 3", 8 ohm drivers in parallel to give 4 ohms
Choose a second order Butterworth crossover at a frequency of no lower than 4,500Hz with the 6 ohm tweeter.
Add an L pad to give 4dB of attenuation to the 6 ohm tweeter. 10W wirewound resistors are adequate.
Perhaps someone will give of their time to develop a perfectly aligned crossover for these drivers, but you will certainly learn more by first experimenting with this approximate method.
Jarryd, you might have better luck posting in the Multi-way forum. While there is some crossover talk here in Full Range, one of the primary goals of designing speakers using full range drivers is the avoidance of crossovers. Good luck with your project!
