2-way cross-over design
Hi Guys,
I'm using a JBL 2234H woofer (8 Ohm) in a 5 cubic ft cab tuned to 28 Hz using 6" port. I'd like to have an 800 Hz cross to a 16 ohm TAD 4002 compression driver. I will only use the very best components (that I can afford) when I build them. If anyone has an appropriate JBL version that would be fine also.
Thank you in advance for your help,
Henry Zuranski
