Is there a sound quality difference between running your current car subwoofer at 4 Ohms(300 Watts) or new subwoofer running 500 Watts at 2 Ohms?
Will be using same amp(capable of either)
The answer has to be YES because you are describing two DIFFERENT woofers,
SO, it depends on the actual specs. of the different drivers 🙂
It also depends on the amplifier.Will be using same amp(capable of either)
To maintain quality it must have energy reserve and be able to work at 2 ohms with good control.
In my opinion it also depends on the combination of all the components.
