2 * Aleph 30 = an Aleph "60"?
I saw a post re scalability of the Alephs, a light bulb went off, I came across locally & bought two of BrianGTs original Aleph 30 “kits” (pcbs, parts and matched output devices).
I’d like to use the 2 kits to make an Aleph “60”. For my 84 dB, 3.1 ohm speakers, the target load is 3 ohms, power into that load min 60 watts, 100 would be a little better.
They will preferably be monoblocks, other than that, I’m open. I guess I could make two Aleph 30 amps, and “parallel” them, which would allow future flexibility, but require 2 more cases . .
As the speakers drop to 3.1 ohms, and it should sound better, I want to bias them as high as possible. It helps a little that I’m in the same city as Conrad.
I searched on aleph 30 bias, but got 1430 hits . .
Has anyone done something like this?
How are the rail voltages, transformers and current calculated?
Thank you
hi,
as i have build it. so i know little bit about it.
pls check the attachment here already stated to changing the watts and how much current do you require.
i hope you can find here.
i am using 10 ampire 29-0-29v..amp output is 30w for now as i am still learning about it. heat sink need to be very big. mine gets alst cound on high volume 46c, amban is 30c. i think the temp is ok....not really bad after 7hers of operating.
best regards
michael
Jacco
I searched on Volks 60 and didn't see much, finding more searching on the Aleph 60 . .
I saw that Grey has said that "the Volksamp 60 is basically an Aleph 2 running at lower bias". Not that bias is the main criteria of good sound, but it should help with that, with the low ohms. But it seems the Aleph 60 should be my "model".
> 25 Vac transformers and biased to 2-1/4 amp
What % current gain did you assume to arrive at those values?
space2000
Your schematic says its for the Aleph 3; I may be wrong but at a quick glance it appears more complex than BrianGT's Aleph 30?
To make a 60 from the 30, apart from doubling the output devices and heatsinks (or more if current gain is increased to say 65%), and larger transformers - what component values need to change?
Here's one in my lingo with a main numbers list of the various Aleph models, 1st one that pops up when i do a Goggle dive.
You'll find identical lists at several home pages of English speaking Aleph builders.
(whenever i really need to find something at Gurgle i run through a dozen different language versions)
Numbers
The Aleph2 has both different rail voltage levels and is biased higher.
Jacco
Thanks for that link, I thought you'd suggested searching just here at diyaudio . .
Btw, I saw you have esl 63s ~ I have Apogee hybrid ribbons . .
To keep the rail voltages around 2*25, but bias the 60 to the level of the Aleph 2, what is the formula for amps bias and the traffo's VA?
Can anyone say if/ which component values in BrianGT's Aleph 30 would need to change?
Thanks ZM!
{The resistor that affects Ac current gain (R21 in the Aleph 2); on BrianGT's Aleph 30 BoM - doesn't appear to be flagged, I'll have to track it down . . }
In Aleph-Power.xls, puzzled that doubling the number of fets makes *no difference to power at any ohms 😕
otto88 said:
Thanks ZM!
that's resistor in series with 220uF - connected from output rail to base of upper ZTX
overall current and PSU voltage is what's count ;
number of outputs will have influence on damping factor , open loop gain and - naturally - on exact dissipation per device
Thanks Zen Mod
the terms in Williams spreadsheet?
eg Transformer wattage - factor 2/ 3 /4
I *think the explanation of factor 2 is
"because the 50% current gain means that the current source delivers 50% of the peak current at idle"
If Ac current gain is 65%, what is the factor: 3 /4?
If your amplifier dissipates 100watts in heat, then a 200VA would be a factor of 2. In diy land we usually want a transformer thats at least 2x 3x total dissipation. For example: I've been building an Aleph 2 for ages now. Each mono block dissipates 300watts in heat at idle. Each block has a 1500VA trafo...for a factor of 5. AC current gain is independent of total dissipation.
Don't under estimate an Aldeph 30
Mr. Pass.
I bought a Aleph 30 clone from a friend and casually lent it to a friend who was in need of an amp. His system comprised of a DIY valve pre-amp, a Theta CD player and a small DIY speaker using a Newform Research ribbon (30 cm ribbon) with a Dynaudio bass driver.
Upon hearing that system my jaw dropped. The musicality of the above combination was exceptional - let alone the fact that the system cost a fraction and much more enjoyable than my Krell home setup.
So gentlemen - do not under-estimate this little amp. In the right combination it can be mind blowing.
Thanks Mr. Pass for making it possible that with a bit of effort- everybody can have good sound.
Jozua
Cape Town
South Africa
Re: Don't under estimate an Aldeph 30
I try not to underestimate any amplifier. If I have an amplifier that
isn't very good in one setup, I think about where else it might be
happy.
