I have 8ohms speakers wired in paralel, could i conect them to 8ohms crossover? what will happened if so? please help.
hey, maybe you will find some here
http://www.diyaudio.com/forums/multi-way/190200-what-effect-does-4-driver-have-8-ohm-crossover.html
Simple. It changes the crossover frequency.
A crossover is just an LCR filter. That is, the inductors and capacitors utilize a set impedance to generate a filter slope. If you change any one component (i.e., capacitor, inductor, or resistance of the driver) the filter will change.
You really need to design a crossover from scratch if you make any changes to the drivers.
