Trying to get my head around driver datasheets
This one lists at 2.83v
https://www.wagneronline.com.au/attachments/Audio-Speakers-PA/sbacoustics/SB34SWPL76-3-DV.pdf
This one at 1w
https://ds18.com/collections/n-12-s...ohm-dvc-quad-stacked-magnets?view=sl-76453B29
How to line the efficiency up to even power to compare?
Also Fs and response, I see some that list frequency response starts around Fs and some that are a lot lower as in the second link with 16Hz on the lower side of response and 31Hz Fs
This one at 1w
We are fortunate that the modelling software don't rely on manufacturers numbers for Sensitivity. Shoddy series and parallel, both done at 2.83v as in case of the SBA. The peak to peak xmax rating also appears to make it look huge when it's only half that
Calculating Vas using the known sensitivity number is useless with such datasheets
The spec sheet clearly states the one meter sensitivity at the voltage applied to the dual voice coils:We are fortunate that the modelling software don't rely on manufacturers numbers for Sensitivity. Shoddy series and parallel, both done at 2.83v as in case of the SBA.
2.83v into 1.5 ohms nominal (parallel) is 5.3 watts (90dB), 2.83v into 6 ohms nominal (series) is 1.33 watts (85dB).
If they stated 1watt sensitivity, 1.225v (square root of 1.5 ohms) would have been used for parallel, and 2.5v (square root of 6 ohms) for series.
The spec sheet clearly states linear coil travel as peak to peak:The peak to peak xmax rating also appears to make it look huge when it's only half that
With the voice coil and gap height listed easy to see this is a real, 38-8=30mm.
Since the definition of Xmax is linear coil travel one way, simply divide 30/2=15.
As far as the DS18 specs, who knows...
You know, just buying the drivers on impulse was easier. Scrutinising datasheets is a jumble of real estate ads
The DATSv3 is going to get a workout
The 1W/1m measurement is likely to be 2.83V/1m, with the "1W" actually being referenced to an 8-ohm resistor.This one lists at 2.83v
This one at 1w
- Subwoofers
- 1w or 2.83v? Fs and response?
