1st project complete
Just finished my first diy project! I made a simple pair of BR cabinets for some fostex 127e's and they sound great.
I thought it would be fun to try and build some full range speakers for my SI t-amp. since I know zip about woodworking, i needed to keep it simple. I used win ISD and settled on an 18 litre box tuned to 62hz. this gives a very slight hump and -3db at about 55hz.
with my plan in place, i ordered the drivers and started to break them in in cardboard boxes. I have to admit i was concerned as they sounded thin and bad.
with my limited skillz, it took me a while to finish the boxes. I don't think any angle is completely square.
Well, i just dropped in the drivers and WOW!. Hey there's bass in there. The driver is very clear and accurate and the bass is much better than I expected. some reggae and hip hop have bass to low for the speaker, but everthing else is OK.
anyway, consider me a convert. I cant believe how good a crap job like mine can sound. I am already planning on building some big tapered pipes to put these drivers in. any suggestions ?
just fired up and wanted to share.
tomjavascript:smilie('🙂')
smile
As you say you want a big tapered pipe, then, assuming you have the rear wall to load it, a reduced version of Terry Cain's Bigger Is Better TQWT (actually a folded corner-backhorn) is on. You'll see the original on the Single Driver Site here:
http://melhuish.org/audio/DIYTQ8.html. However, that's going to be a bit over-large for the smaller FE127E -certainly over-long at any rate. Dimensions I'd use for the for the FE127E assuming 3/4" build material:
Height: not including whatever base you wish to give it, 52 1/4".(I've set 1/4 wave tuning to 65Hz here, fractionally below the Fs of the driver)
Width: 7" (external)
Depth: 10 1/4" (external)
Driver height from base: 29"
Internal baffle terminates 4" from the floor of the cabient and 4" from the front and rear baffle internal walls.
Cheers
Scott
