1875 heatsinking (bolt to steel plate?)
I'm making a computer speaker system w/ sub and lm1875 amp for the fullrangers. I built the 1875 amp, and bolted both channels to one relatively small heatsink, and the thing doesn't get warm! I'm really surprised at how cool it stays.
I want to build all of the amps into the sub cabinet. My sub amp is a purchased plate amp. I am thinking about modding the plate amp by removing the power transformer, and moving it somewhere else. Then I will have plenty of free space for my chipamp.
Do you think I can just bolt the 1875's to the steel plate of the plate amp? The plate is 10x10, but the area that is just a solid open plate, w/ no holes or other heat generating parts is about 4x10x1/8"thick.
As w/ all plate amps, it also has a heatsink which the sub amp parts bolt to, and that is below the area I'm thinking of using for these 1875's.
what do u think????
thanks,
Scott
Did you use thermal grease? If not the metal stays cool, although the LM1875 is already cooking.
Have a look at the datasheet. On page 4 there are graphs that show the power dissipation for several supply voltages and speaker impedances. On page 3 there is a graph that shows the possible power dissipation for several thermal resistances of heatsinks.
At the bottom of this page you can download a calculator to find out the thermal resistance of your heatsink.
Thanks! That website should help.
On the 1875's now, yes, I used some 'arctic silver' thermal grease, and I do know how to use it properly. I'm used to class A amps, which is why to me, this 1875 is staying cool. The heatsink does get slightly warm, but not hot. And I think it's pretty small. 5"long, 1.5" tall, and 3/4" deep fins, and both channels are bolted to it. Also, it's the clamp type mounting, not just the single bolt through the hole on the chip.
