16x9 or 4x3
I went for the wide screen version as I will be using my projector to watch alot of normal TV programs as well as dvds and gaming. The majority of programs here in Australia are broadcast in l widescreen so my choice was easy. Obviously both will play widescreen but you will get black bars top and bottom of the screen with the 4:3 And the same lens will do both 🙂
Either way the Lilliput is an excellent choice you will be rapt with the results from either versions, good luck with your project look forward to seeing the results mate ;-)
