16 ohm drivers?
You could run a 160 ohm driver on a "regular" amp and it wouldnt hurt it.
The higher the impedance, the lower the "draw" on the amp. So yes, you can. But remember, you will only get about half the power into a 16 ohm speaker as you would an 8 ohm.
And half the distorion (in general)
Power shouldnt be a problem, this speaker will get the (claimed) 100wpc into 8 ohms from my mass market reciever. Your distrortion statement intrigues me though - my reciever (Pionerr 811s) has a pretty weak amp section, and does not 'officially support' a 4 ohm load, does this mean it will have an easier time driving a 16ohm speaker than an 8ohm speaker? Because with my big floorstanding 8ohm towers, it is not very dynamic, I ended up using the preamp outs for the front channels so I could use an outboard amp with some balls (1970's Yamaha reciever), and it would be nice to avoid the need for a separate amp for this speaker (center channel).
Maybe you lose less than the theoretical 3dB with 16 Ohm series using small tube amps, especially SET? I would expect so with a high output impedance amp. Did you ever measure SPL when parallel (4 Ohm) double drivers vs series (16 Ohm) when fed off an 8 Ohm tap? Speakers are governed by voltage, so maybe less of a loss than expected? Do you subjectively feel not so much of an spl loss when using push push 16 Ohm vs push push 4 Ohm with tube amps? Planet 10?
Take an amp, solid state or otherwise, designed for an 8 ohm speaker.
Take 2 eight ohm speakers, each rated 90 dB at 1 watt, (2.8 volts for an 8 ohm speaker).
A single 8 ohm speaker, at 2.83 volts, will be playing at 90 dB. Add another speaker in parallel, and they will be playing at 96 dB. However, they will be drawing twice the current. Nevertheless, at any given voltage level, the parallel pair will be 6 dB louder than the single 8 ohm.
Now, take the same single 8 ohm speaker at 2.83 volts, playing at 90 dB. Add another identical speaker in series. the series pair will still be playing at 90 dB at 2.83 volts. However, they will, together, be drawing half the current of the single 8 ohm speaker, therefore, they will be running at half the power. But they will still put out the same SPL as the single 8 ohm at the same voltage level-in this case, 2.83 volts.
To summarize:
2.83 volts = 1 watt ONLY for an 8 ohm load.
A) (1) 8 ohm speaker at 2.83 volts = 1 watt drawn = 90 dB.
B) (2) 8 ohm speakers in parallel at 2.83 volts = 2 watts drawn = 96 dB.
C) (2) 8 ohm speakers in series at 2.83 volts = 1/2 watt drawn = 90 dB.
The extra 3 dB SPL for B and C comes from the fact that they have twice the cone area of A.
I definitely notice a loss when wiring series vs. parallel on bipole applications. It does take a little more power to get the drivers going but the amp has a much easier time with control regardless of it being tubed or SS. Nelson Pass' First Watt article does a good job of explaining this. A pair of WR125ST wired in parallel should give you 88db/1W with excellent control, as they are designed to. I heard the WR125S pushed with a typical Japanese solid state receiver and it still sounded great. I'm going to get a pair (not the 16 ohm model) and try them out on my EL34 push-pull. I'm going have to make shelf space for XBL^2 based drivers now. :xeye:
kelticwizard
I was seeking practical driveability and subjective spl feel information over many FR types considering the output trafo limitations of lil tube amps despite the well known scalar and wattage addition math. Any experience with that? For instance I measured only 2dB loss from 16 Ohm series vs 4 Ohm on such an amp's 8 Ohm tap. Considering the higher impedance tube output stage loading derived, less distortion reported is well founded.
To put it simple. Is 16 ohm always subjectively preferable when with SETs and the like?
Good explanation Peter... but it rests on the above incorrect statement.
A 2nd driver in parallel, gives you 3 dB more (ie 93 dB) given the same 1 watt in...
the myth you have stated comes from many people assumming all amps double their power into half the impedance and therfore put out 2 W into the now 4 ohm load. In actuallity the amps that double (or even come close) into 4 ohms vrs 8 ohms are actually only a small subset of the set of amplifiers).
dave
p10, let me nuance that a bit. What you say is exactly correct when considering maximum power. But I think that most 20 watt amps, for example, would indeed double their power into 4 ohms versus 8 ohms at the 2 watt level. Not exactly, because source impedances aren't zero, but they're usually pretty small.
Yes, that is why I stated it as 2.83 volts in, and not "1 watt in".
planet10 said:
...the myth you have stated comes from many people assumming all amps double their power into half the impedance and therfore put out 2 W into the now 4 ohm load. In actuallity the amps that double (or even come close) into 4 ohms vrs 8 ohms are actually only a small subset of the set of amplifiers).
dave
I gave the answer for small to intermediate power levels, and figured the absolute max level could wait for later in the discussion.
Brett said:
Good analysis KW, but doesn't it omit the finite output Z of the amp, which is quite often large in tube amps wrt the speakers Z, and assume that the amp has an output Z of 0R?
You are absolutely correct, I did assume an output Z of zero, figuring, perhaps incorrectly, that while tube amps have higher output Zs than solid state, the output Z of a tube is low enough to make the analysis workable.
If in fact the output Z of a tube amp does make a real difference, my analysis goes out the window.
