+/- 15vdc psu help
ok, I read up a little bit and I connected the ground going to the bridge from the ct of the tranny. (Duh, you say??) And I have now +15vdc and -8.9. I think my 7915 may be in backwards, but It is hard to tell, I am really dislexic! The 7815 is installed the same way and it works fine, but the 7915 is super hot and not outputting correctly. weird. I made a pcb from the gyreaf drawing, but like I said I swapped the inputs from the ac to the bridge.
