+/-15V Power Supply for opamp
Hi Ray,
I am bit nervous workign with power.
Ive done enough maybe with the upgrades - diodes, vishay cmf55 resistor, NJM7805 regulator slimicII, KW and spare Jantzen superior z caps i had spare, and my spare Eichmann RCAs
mkps are in the decouping and output
Sounds great as is, would the extra trouble be worth it
Sounds great as is, would the extra trouble be worth it.
Maybe you should hold off until you have more confidence. There's no guarantee that
replacing the existing power supply will be an improvement. Maybe, maybe not.
There are better circuits than the 317 regulators. They're just a step up from the
usual fixed output three terminal types.
yes its a very small power supply that is stock, less tricking then giving a separate power supply to the opamp. It has a couple of numbers written on it, i would need a supply with the same leads, and see what voltage is applied to each wire on the connector
