135mm long-throw lense kit from diylabs
Is any one using the long-throw 135mm lense from diyprojectorcompany (alan). I ordered the kit with the lense and fresnals to match - the NZ exchange rate is a killer - doubled the price.
Anyway - is anyone using this lense and what are your results?
I have a 15" cmv1515 lcd and a 400w metal halide. I figured with the bigger lense and lcd i would need the biggest light i could find.
The lense is marketed so you can set the projector much further back from the screen and still get a managable size image - it sounded good to me - if anyone has an opinion or results from using this kit can you let me know.
When the lense kit shows up i will put the bad-boy together and post some results.
Also what is your opinion on reflectors behind the light - growers use gloss white painted surfaces on their reflectors - would this be better than a mirror finish on a metal reflector?
Im going to use an aluminum reflector and polish it till it glows - give me your opinion on this.
Cheers everyone - these forums have made my desicisions much easier for parts selection!!!
keep up the good work!
ancorp said:
I got an identical-looking lens with the same specs, seems like an excellent lens, worked well for my 17" flat crt to project it onto a 60 in screen.
were the corners 100% focused? anyway your throw on this test was quite short (2meters?) that means the lens_back--tv distance was long (51cm?) so it is not the way most of us will use it. I´m triyng to determine the FOV of 135mm lens but i can´t believe manufacturers don´t know it.
i think this thifference on the throw can be fixed placing the lamp closer to the rear fresnell.
You mean 17" works right with 135 triplet? do you know the FOV JCB? your store has a pdf wit specs but i can´t download them.
JCB wrote: I emailed the company and am still waiting on a reply
no news? Why does nobody know the FOV of this lens? I think it is not interesting for you to make it known. All the tryes makin 17" with 135 triplet that i see are black cornered. I think that the FOV is just too thin for this kind of TFT.
Would like to hear coments about it.
Hi Rox,
Sorry for the really delayed reply (missed your post). Yes, the corners seemed 100% focused (I can actually do a re-test if it really matters) Remeber its a 17"CRT, thats like a 16" LCD. I also Tested the lens with a 20" TV, and it seemed to be right on the limits (got the corners, but the lens had to be almost dead center, no lens shifting). Yes, the throw was about 2 meters, same with the TV, abit more, with an image of about like 70-100 inches. With a proper enclosure and screen, a 20" tv with this lens will give a nice 60-100 inch picture (abit on the dark side, but with proper service mode adjustments, shouldnt be a problem)
Hope this helps,
Alex
thanks for your information but it is not very usefull my friend.
the throws you are using are too short. Thats why you need to place the lens so far from the image source (so 17" 16"real image enters the triplet even thought its small FOV.
The isues come when you use 17" tft real (17") and the trhow is 3m lets say. then the triplet is so close that the tft is outside of its FOV. So it does not work at the corners.
But the only thing i would like to know is the FOV value of this lens. Its getting hard to find it!!!!!! sellers seem not to share it with us, i wonder why 😀
Rox, I direct you to this thread:
http://www.lumenlab.com/forums/index.php?showtopic=5230
His site has more info.
Basically, he got it to work by using the lamp at 220mm instead of the 330mm focal length. This made the effective focal length I think ~450mm, and combined with taking apart the triplet, got him reasonably sharp (I didn't see close enough for screendoor, but individual pixellation is visible) images.
I'm thinking that that's how I'm going to do it.
