12V Trigger for X150.5
thanks for all replies!
one more qns, the X150.5 12V trigger has same configuration as speaker out, i.e 1 Red and 1 Black terminal, and looks like it only takes spades.
some of the pre amp only has a single 1/8" mini plug 12V trigger out.. how to I connect it to the Red/Black terminal of the X150.5?
thanks
thanks
Make a custom cable. Verify this, but usually the front portion of a mini plug is plus and the longer section near the base is ground.
-David
thanks dw8083
one more qns.
understand that the 12V trigger terminals of the X150.5 draws current of about 5mA. can i supply a output of 12V and 2.5A to it? will it cause any damages to the amp?
-David
The trigger circuit will draw the current it needs and having a PSU that can supply more is just overkill.
Perhaps you are using the 12vdc for other purposes as well? You could always build a second 12vdc regulator hanging off the rectifier of your larger 12vdc supply. It does not appear the trigger circuit needs to be regulated. The specification for this amp states 9-15vdc at 5ma.
-David
