12 volt battery voltage step up
hey, I just took apart an old battery backup surge protector that's battery side wasn't working. I'm assuming it was just a fuse or some other part, as the battery still has a monsterous charge.
I got a really nice 12 volt 4ah/20hr rechargeable battery thats only a little bigger than one of those 6 volt lantern batteries. My question is how did they up the voltage in the circuit to 120 for when power goes out? Did they use a Step-up transformer?
I'd like to make a sort of inverter, kind of like what they use to up the voltage from a car battery to AC 120 for running appliances.
What I would really like to do is only up it to 32 volts @ 2 amps or 40 volts @ 1 amp so I can use this in a 50 watt guitar amp I am building. I also would like to know how to build something to charge the battery with.
So Is this possible? If so, how?
Thanks for any help!
