Can anyone help me if there is a recommended 12" tapped horn design works well from 45-125Hz soundwise and performance wise? Must be designed around two different brands available here in the USA I prefer Faital Pro 12" if it can be used as an alternate woofer (new ferrite line)? Thanks everyone!😉
There are MANY brands available in the US. And FaitalPro looks to have at least nine 12" models. What exactly are you looking for?
I believe Art (weltersys) is working on one for that exact low corner right now....
With a B&C 12" I'm pretty sure...
12" Tapped Horn Plans?
Thanks for the reply I was thinking of using the 12 HP1030 12.45mm Xmax or (12HP1010 cheaper) expensive but willing to cut some of my savings in the bank, wifey doesn't know hehehehe . . . .😀
FaitalPRO - Professional Loudspeakers Made in Italy
Nice looking driver, I wonder when it will be available and how much it will cost.
From what I have seen, Faital announces product well in advance of availability.
With a No=.83% (91.2dB) it's not very efficient either, although a TH will probably add as much as 6dB or so.
No=1.25% (93dB)
x-max=11.17mm (Faital method of gap height/3 plus coil overhang)
LF Cast Chassis / Ferrite - FTR12-4080HDX - Celestion - Guitar, Bass & Pro Audio Speakers
$99 from Recone Kits
±2dB 45hz~150hz, 99dB average at 2.83V/1M, does not exceed x-max with 80V RMS sine wave! 100.6dB at 50hz 2.83V/1M
About 129 liters (net).
******************************8
| 45 Hz Tapped Horn
Def_Const |Horn Dimensions
a1 = 150e-4; |Area at throat (cm^2)
a2 = 200e-4; |Area at rear of driver (cm^2)
a3 = 1100e-4; |Area at front of driver (cm^2)
a4 = 1200e-4; |Area at mouth (cm^2)
l1 = 18e-2; |Distance from throat to rear of driver (cm)
l2 = 195e-2; |Line distance from rear of driver to front of driver (cm)
l3 = 25e-2; |Distance from front of driver to mouth (cm)
Def_Driver 'Dr1'
| Celestion FTR12-4080HDX
Sd=530cm2
fs=61.2Hz
Qes=0.446
Qms=2.28
Vas=24.79L
Re=6.05ohm
Le=1.92mH
system 'S1'
Driver Def='Dr1' Node=1=0=3=4
Waveguide 'W1' Node=2=3 STh={a1} SMo={a2} Len={l1} Conical
Waveguide 'W2' Node=3=4 STh={a2} SMo={a3} Len={l2} Conical
Horn 'H1' Node=4 STh={a3} SMo={a4} Len={l3} Conical
| 45 Hz Tapped Horn
Def_Driver 'Dr1'
Sd=530cm2
fs=61.2Hz
Qes=0.446
Qms=2.28
Vas=24.79L
Re=6.05ohm
Le=1.92mH
system 'S1'
They will be available in the US 1st quarter '12, Sensitivity for the 1030 is 95dB, 1010 is 96dB price MAP $348 1030 and $270 for 1010. I am leaning towards the 1030 2 X tapped cabinets. Thanks!🙂
This design will do it. The 12PS100 drivers are reasonably priced and if you have a wholesale account they are two for the price of one 1030.
http://www.diyaudio.com/forums/subwoofers/208562-tinyhorn.html
This is a design I've been working on, the THAM12, perhaps it can be of intrest, drawings and numrous simulations can be found in the link below:
http://www.martinsson.cc/blog/index.php?entry=THAM12
It's about half the size of the THAM15, I have not built these yet so I can not comment on real world performance.
TundraLTD, that design of yours sure looks nice, great response, and I really like the folding 🙂
I really want to use the Faital Pro brand I like the PS100, I've used B&C, 18Sound, RCF's, PD's (1850's) and really want to try faital his time around.
On another note Martinsson, I am just curious how did you fit the Turbo TSE111 phase plug to fit the B&C 10MD26??? You say it sounds good, the Fane has a different cone size and flatter on the cap??? Just curious, Thanks!
Is the MTH-30 pretty good with the Faital 12HP1010? Thanks everyone!😉
"They will be available in the US 1st quarter '12, Sensitivity for the 1030 is 95dB, 1010 is 96dB price MAP $348 1030 and $270 for 1010. I am leaning towards the 1030 2 X tapped cabinets. "
The sensitivity for any driver is in its mid-band, and has little to do with its efficiency in the bass.
Compare the Eta Zero (No%), and even then, some drivers work better than others in a TH.
The Celestion is a much better driver for the TH requirement you expressed, it is more efficient, and a fraction of the price.
Thanks , folding gives me a headache! It took me an entire day to make it work. I'm building a pair this weekend!
- Subwoofers
- 12" tapped Horn Plans?
