Any suggestions for suitable 3", 3.5" or 4" that would suit max. 100mm cutout, and be happy playing with 2.5 litres volume...
Pushing it....capable of 100-110Hz f-3dB? Sealed?
You will get close with one of these
Peerless by Tymphany 830986 3" Full Range Woofer
or
Peerless by Tymphany 830987 3" Full-Range Woofer
or
Thanks,
I should have replied here but I had to give up the 100-100Hz goal.
I stumbled upon some Faital 4FE35 very cheap and bought them.
They fulfill most of the requirements, and may just mean a FAST system is on the cards now.
I agree the neo 4Fe32 is a smoother beast above 8k, if the specs are accurate, regardless of impedance, and to varying degrees.
But the 4FE35 is not bad at all, and for £10, and not £30, even better. With some luck I should be able to tweak the notch down to 8k
Any good sources for 12" diameter sonotube?
I have a whacky idea brewing
I have to admit to not paying much attention to MA recently, and also, to be fair, I havent seen them half as prolifically as a few years ago.
Don’t know what the 4F will do, but the 3F i have is quite decent. In a 2.5 litre uFai-Ken (and the MA & Fostex versions), you are getting something like 75 Hz F10, anechoic. In use near-field, especially if near wall/desktop “room” gain should be significant, won’t play loud real low but likely won’t need to.
If you can find some 3.5” A6.2m or p, they fit 2.5 litre box.
I know their were some in France, i have a few pairs. KJF has none, D’Archer in Oz has the A6 metal (he has some of the more sought after A10p too)
dave
dave
