I am looking to purchase some ALPS pots from e-bay and the guy is selling three types, 100K, 250K, 500K.
Which one will be most suitable for a Gainclone design (using either LM3886 or LM4780)?
250K and 500k types are mostly used for replacing pots in old tube equipment. 50k or 100k is more suitable for your purpose.
Best regards,
Mikkel C. Simonsen
Best regards,
Mikkel C. Simonsen
I am planning to use an OPA627 based buffer in my setup, so does the POT value really matter when using a buffer?
The POT will be located before the buffer!
Yes, 250k and 500k are still only for old tube circuits 🙂
For new tube circuits you would use 50-100k also.
Best regards,
Mikkel C. Simonsen
Best regards,
Mikkel C. Simonsen
As Peter said 50 k or even lower. I would have take 10 kohms if it had fit. Less resistance, less noise and sometimes less offset shifts.
