I built a center channel speaker using a couple of factory buyouts and have a peak between 100 and 250Hz. I there anyway to get rid of it in the crossover? I'm using 2, 5 1/4" with a 1" tweet. My box is ported and tuned to around 75Hz. If I plug the port I get a smoother rolloff but no change above 100Hz. Really messes up the voices. Drivers are HP-5210 from parts express. Thanks
I just tried disconnecting one of the woofers, checked it with REW and still up 7db in that range. I recalculated my box volume, its .44 cu. Ft. After subtracting about 30 percent for drivers, crossover and port I am probably to small. Also, my slot port is in the middle so I wonder if that messes up the volume. I tried stuffing the hell out of it thinking I had resonance but that only smoothed the bottom end rolloff like when o stuffed a sock in the port. Probably just need to use these drivers for something other than center channel that's not all voices.
Try changing the height and tilt it up/down and see if you can put the floor diffraction null in this band. If you`re open to modifications - close the port and convert it to an a-periodic - you will loose some dynamics but this will equalize the peak, just vary the amount of resistive material in the hole until you get it right. Packaging foam ( the charcoal one ) works great.
Hey Andrew,
Do you have a pic of the speaker in place and a graph?
Best,
Erik
You must short the disconnected woofer, put some wire across + and - woofer terminals.I just tried disconnecting one of the woofers, checked it with REW and still up 7db in that range.
Be careful with this.
If the two drivers are connected in parallel your amplifier probably wont like a short circuit across its terminals. 😱
This problem is easy to solve using EQ. Acoustic countermeasures are much harder to do. Does your receiver have a built-in equalizer?
Another thing that could work is to add a series capacitor to the woofers. You might need to seal the port. A simulation program will tell, for example Boxsim. The capacitor will NOT just work as a high pass filter, as the impedance of the woofers is far from flat around the lower end of the pass band.
Of course disconnected woofer is out of circuit! Than it should be shorted, because if not shorted it will behave like a passive radiator.If the two drivers are connected in parallel your amplifier probably wont like a short circuit across its terminals. 😱
- 100Hz-200Hz peak
