10" jaycar sub
10" jaycar xl sub
hi i was thinking of getting this http://www1.jaycar.com.au/productVi...xxx&pageNumber=&priceMin=&priceMax=&SUBCATID=
and powering it with this
do u think it will sound good or will it be bad qualty and a waste of money. i dont have mutch money at the moment so this is about the max i can spend so if u know anything cheaper that is better can u help me.
oh yeah i want loud bass im sick of my small speakers with no bass.
thanks
Ben_s
10" jaycar xl sub
thanks
Ben_s
wsin jaycar the other day and was ooking at the 12" version of the XL seres and it looked like a real beast, i pushed on the cone and it really moved a decent way, anyway my suggestionis to get the 12" version and get a plate amp from wes components, they sell a 200w for but 250, it just doesnt have binding posts but i think the drop in price is well worth that sacrifice.
Ben
If you want to save some money these amp are always for sale on ebay (I picked up a 350W for $260 plus $30 P/H).
Or, if you have an ABN get your hands on an Electus Distribution wholesale catalogue http://www1.electusdistribution.com.au/ These are the guys that supply Jaycar and they sell the 150W for $178, 240W for $230 and the 350W for $290 (plus GST)
Hope this help
Jye
Hope this help
Jye
wow jye thats amazing prices, with your abn does you business/occupation have to have anything to do with speakers/audio? and can our wonderful tax dept ping us for it?
Michael
I uses the ABN of a sign making business (no link to speaker that I can see). As for tax never had a problem. You can also get wholesale prices from Wes.
Cheers
Jye
Cheers
Jye
You can use anyones ABN . even someone you know or work with . the only way to get a ABN is from the tax office
just remember the wes amps are 4 ohmns only
if you can get a trade price with wes you might be able to get a peerless driiver instead
http://www.wagner.net.au/Catalogue/06_37.pdf
busterno1 said:just remember the wes amps are 4 ohmns only
[/url]
🙄 I am pretty sure that is impossible...
Its just the wes catalogue states on 2 out of the 4 that they are 4 ohmns
http://www.wagner.net.au/Catalogue/06_39.pdf
the other 2 no rating
the 200watt amp will probably give like 100-150watts into 8 ohms...
the ones without the speaker impedence stated are probably also into 4 ohms..... and all the amps can probably do 50-75% of their 4ohm rated power into 8 ohms....
Ben,
I have yet to hear a Jaycar sub that I thought was suitable for music. I think you get better quality and value if you look at some other drivers, which include:
Adire Shiva ($300 at Acoustic Visions)
Peerless XLS 10" or 12" (190/220)
Peerless CSX 10" (97.50 at Wes trade price)
Don't be fooled by the large surrounds on the Jaycar subs - some of them have no more excursion cability than my Vifa 6.5" drivers!!! Their bark is worse than their bite. Their most expensive subs are bigger and more expensive than the Shiva, but none of them can match the quality or output. These drivers only have two advantages:
1. you can hear them at the shop
2. more attention is paid to their appearance
For subs available in Australia, I'd look at Adire or Peerless. I can't say that I have heard the CSX, but I have heard good things about it, and it has a motor designed for low distortion, a rare feature in a sub at this price point.
regards,
Paul
regards,
Paul
so i fi got the Peerless CSX 10" what amp do u recon i will need to power it. i want loud low bass.
The CSX is rated at 200 watts rms, its thermal rating. Not sure about how much to use its xmax, however that will depend on the box and alignment. I'd say at least go with the Jaycar 150watt rms (100 into 8 ohms). The 240 watt amp will give you extra headroom and the 350 watt amp will probably have more power than you would need, although the remote is a handy feature.
The plate amps available at Wes Components are cheaper. The 200 watt version is cheaper than the jaycar 100 watt amp (both into 8 ohms).
I haven't used any of these amps, I have a hifi power amp, but they are generally recommended.
regards,
Paul
regards,
Paul
definately go the ported, it will provide much higher output and lower response. my box is 100L and tuned to 24Hz, more was done today and now i just need to screw in the driver and glue the port in to do some testing.
ill order my plate amp in a few days when i get paid next. i will simply cut a hole in the back with a jigsaw and slap the amp in.
ill be happy to run you through the project if you decide to undertake it.
- Subwoofers
- 10" jaycar sub
