I have looked for this cap at mouser and allied electronics and I can't find it! Where are you guys getting this part? I did find one, but it is as big as a 20uF 500V cap. Any ideas?
Thanks!
Thanks!
Where are you planning to put this cap?
0.1u/3000V ceramic?Something going on here.
If you have a scanner, put it in and let as see this cap to help you.
I have read several times that people say that putting this cap across the high voltage secondary will help reduce noise.
MarshallPlexi said:I have read several times that people say that putting this cap across the high voltage secondary will help reduce noise.
I have personally found this so too.
But, you don't need one so big - 0.01 to 0.047uF will do you fine.
