Need help identifying burnt part on water damaged Harman Becker amplifier. Part # 9320214 - model BE B220. I am trying to repair this unit and one component is burnt beyond recognition. It has 4 pins and is SMD package.
Attached are pictures of where the component is on the PC board. If anyone has an amplifier that is model BE B220 or similar and could take a high resolution picture of the component so I can get the SMD code from it I can look it up.
I have already identified all the other blown parts that need replaced, just need this last part identified so I can start repair.
https://www.diyaudio.com/community/forums/car-audio.38/
Maybe ask a moderator to move your car audio post to the Car Audio section.
