We've had previous discussions on this design but my issue remain unresolved. The design is largely cosmetic. The two 6" bass drivers are the same save for the dust caps.
My questions. If you disconnect one of the woofers are you left with a 2-way, passive radiator design?
Two: If you install a genuine 3-way crossover does the mid-range driver still serve duties as a passive radiator?
if you do this, you would want those drivers to be each housed in their own separate sub-enclosures. so no, you dont want the midrange to have any physical interaction with the woofer.you install a genuine 3-way crossover does the mid-range driver still serve duties as a passive radiator?
Why not?if you do this, you would want those drivers to be each housed in their own separate sub-enclosures. so no, you dont want the midrange to have any physical interaction with the woofer.
because if they are both in the same air volume, the woofer excursion would cause the midrange to act like a passive radiator, HOWEVER since it is an actively driven midrange, that motion would be resisted by the actual midrange motor. it creates backcurrent, and heat on the midrange. not to mention possibly causing the midrange to hit ecursion limits.Why not?
IF you want to drive both woofers in the same box airspace, go for a 2.5way crossover design.
