Hello,
I'm working on a device that needs to switch between two AES3 audio channels. For this purpose, I’m considering using the TS5A22362 analog multiplexer.
According to the datasheet, the TS5A22362 supports up to 5.5 Vpp signals, while AES3 signals are typically defined as 2–7 Vpp. Given this, is it still a good idea to use this part, or would you recommend a different solution? If it is fine, should i supply 5V to VDD for the best performance? Will this design be reliable for all types of audio equipment?
I’ve also heard that using relays with gold-plated contacts might offer better performance in terms of jitter. Could you please advise on this?
