Need help hooking up the main speaker system's remote.
rggl front rggl
rggl back rggl
Caution: floating grounds do not use with common ground system /What does this mean for me, hooking up four speakers?
Next is the main in /pre out front
back main in /pre out
2ch a,b both/4ch a,b and both
How to get them all to play on at once a b and a+b
tape 1___tape2
front and back
play and record
been working on this for weeks, think I got it, then I don't like the way it works, also some speakers don't work on a , b or both some speakers on sometimes, and then on with all
still have to find out how to hook up equalizer and subwoofer if I can to this old Planar XR4120 FOUR/2-channel BRIDGED RECEIVER????
I DO NOT KNOW HOW TO TRANSFER FROM ANDROID CELL TO THIS CHROMEBOOK SO NO PHOTOS UNLESS I CAN SEND TO MAIL OR SOMETHING
rggl front rggl
rggl back rggl
tape 1___tape2
front and back
play and record
Welcome to the forum. I've moved this thread to Solid State.
Are you able to email photos to yourself on the chromebook?
hey allen don't know have not tried but i think i have another way to do it from my main Imac so lets wait see if that works ok? what is solid state is that a special place for help on here?
The Solid State subforum is for questions about amplifiers that use transistors.
Is this your amp?
Is this your amp?
i hope this is not too long a post for here>What are you doing with my amp? lol yes it is... so that is what i need help with setting up all my components to it, to work together... a channel b channel both on both the 2ch and 4 channel settings. How to add or hook up speakers on it so that they work on all ... can i add an equalizer and a non-powered sub woofer? i have added my CD player and my two turntables, and a reel-to-reel. So what settings do i need to be on? What are those metal U-clamps that are plugged into the main in and preamp out? i have Y RCA adapters. i have wired,,then to RCA plug... to add extras where there are not enough jacks, if that helps
Yes i will later today it will have on the main and remotes speaker wires I know have connected as now at least I have sound but it maybe wrong set up as it is one positive to a neg of other block music comes out louder than if it is pos to neg from one block to another I do not get any thing working on all channels if I put pos red and neg black together on main side.. or am I to use the immediate block to the bottom instead of to the remotes<<<<<<<<I also want to say thank you for all your help up to this point I am in wow this is a very helpful person..
- help needed old planar amp receiver
