Zapco AG150 help!
I picked up a Zapco AG150 that someone else started working on. When testing it on a 2.2A current limiting supply it will try to draw the full 2.2A but in pulses. I removed the rectifiers and it only draws .25A with no pulses. The power supply transistors have a sine wave input and output. All of the output and power supply transistors have been replaced and I am not confident that they are correct as I had another amp from the same person with the incorrect fets installed. A schematic or part identification would be great. Any thoughts on the repair would be great also.
The first image is the output of the IRFZ44 and the second image is after it goes through the transformer (input to the rectifiers). The rectifiers are removed. I am new to the amplifier circuitry but the other amps that I have worked on still had a nice square wave with the rectifiers removed.
Yes. If the transistors aren't tightly clamped to the heatsink, you must very closely watch their temperature.
As a side note on the ground point, if there is complete isolation from primary to secondary or a very high value coupling resistor, you must use the appropriate grounding point to get a reliable reading.
