Weller WU81
You have to be pro-active about avoiding oxide build-up on a bit. Always clean regularly, always re-tin the bit before putting it back in the holster. Once the oxide is thick enough flux won't be able to remove it and eventually abrasion will be needed, which reduces the thickness of the iron-plating - once you have worn through the iron plating the bit is junk...
