Japanese 2A3 schematic opinion wanted
I'm a noob so I'm looking for an opinion of this schematic. There is an amp for sale locally to me that uses it. I've reversed imaged searched it and it appears to be only floating around Japanese and Chinese websites. I'll be looking to upgrade the transformers and other parts but just wanted to know if it would be worth getting first. I'll maybe convert it to a 45 too down the line.
Cheers!
Thanks everyone. I should have been more clear, this particular amp has a single 2.5k tap on the output transformers. It's my understanding that I'd need 5k for a 45. It's reasonably priced and nicely laid out inside so I'm confident I could swap the Chinese output transformers for some nicer ones in the future. I'd like to use it as a platform to learn more about tubes amps rather than jumping in and building one from scratch.
If you connect 8ohm speakers to 4ohm output, you'll get 5K load for 45 tube.
That's shown in the shematics too, so you don't need primary tap unless your speakers are 4ohm.
But if you think output transformers are not of proper quality, feel free to replace them.
The first voltage amplifier section is not sophisticated:
The 250k pot gives variable source impedance: This is 62,5k at middle position. The 6SL7's Miller capacitance is 140-150 pF. The result is the 0 to 10 microseconds time constant (worst case under 20kHz -3dB).
The pot isn't enough safe alone at grid (contact drop). I suggest the redundant R (grid to earth).
Reactions: banat
