I have a pair of OB's of my own design that will be featured in a future post. They consist of a pair of ESS 10's per side accompanied with one GRS 8" planar driver per side with a miniDSP HD for crossover duties. After a year of playing around with different X/O configurations I'm pretty sure a passive X/O should be fairly easy to implement. I'm currently running a 12dB low pass and 6dB high pass X/O with just a bit of EQ provided by the Wiim pro plus I'm using as a preamp (Don't knock it till you try it).
