Tips & Tricks loudspeaker building How to
Joined 2008
A thread on this topic could be an inspiration for newbees & interested folks
Here some ideas I realized:
glued in egg crates (the real ones) and using a thin sheet of damping. Thats for being localized more in the middle of the box where it is damping lower frequencies than only being positioned on the walls
reflex port in the corner of one wall as a cutout and port made of cardboard sheets glued in. Easy to realize bigger port diameters like this.
piezo tweeter on the side for indirect high frequency dispersion but it can be put on and off to taste
once I saw in the 90ies a french hifi shop owner using lead.
He made a mass loaded construction of a loudspeaker enclosure:
38 mm particle board and four layers of lead sheets glued with ceramic glue which got hard after finishing binding process.
A tweak for fullrange drivers is putting away the dustcap.
Its probable to get more highs like this.
This is due to a lot of added emanating surface which is enclosed by a dustcap.
So if dust is not a problem.
See "how to make a whizzer cone" for diy adding of dustcap / whizzer directly to a voice coil.
This 38cm loudspeaker is prepared for a marriage with a piezo tweeter at 4khz.
Also added diy a copper ring on the pole piece. See extra thread on this "how to faraday".
Measurement on axis near field 15cm. Above 3khz more radiation without dustcap.
you can adjust the amount of optimal resistance to your speaker by grouping single litz wires together until the sound gets right.
here I used three single litz wires until it was perfect.
This is for home hifi only! Not PA use!
