HI Everyone,
I have a Levinson 31.5 Transport that was working beautifully. The motor/gear for the close/open lid quit working. But it still plays CDs.
Maxon was the motor/gear OEM. I contacted them with the gear number and motor number. The told me that since the motor is 20+ years old
they could not cross reference this motor/gear any longer.
Please, I needing help finding the DC voltage. Or a spare motor. LOL
I believe when the motor stopped working, the power supple for the motor went out also. I am only getting about 2 to 5VDC momentarily when
I hit the open /close button over and over. I believe the motor is bad because I feed it 5vdc up to 12vdc and nothing happened. I tried rotating the motor
armature shaft with plyers and it will not move.
Any help would be greatly appreciated.
Thanks so much for you valuable time,
Tom
Tom
I've only taken it apart once. It's been so long that I've forgotten it. That time, the carbon brush of the motor was damaged, and it was ready to use if it was replaced with a new one.
