~How much power to expect from TDA7498 with 20v supply/8 ohm and 24v supply 15 ohms?
due to driver and cost restrictions my upcoming boombox will have its 8 ohm woofer driven by a 20 volt tool battery supply mono TDA7498 and its mid-treble 16 ohm drivers with 24 volt tool battery 2.0 TDA7498.
How much reasonably clean power should I expect with each of those amp/speaker combos?
Not 16 ohms load but it does have 8 ohms load power measurements before clipping. Will give you just broad idea of poer. Board is stereo and may be different. Power measurement result at different power supply is at around 12.55 time.
Sound like my big box will be seriously underpowered. Fosi specs the TDA7498 woofer amp only up to 24V - I don't know if that means a fully charged 24v tool battery is too much for it - or not.
The 2 channel amp is rated to 35V supply.
I could parallel the 16 ohm Alphalite 6B and run those and the piezo from a mono amp - tho the amps in the pic below are already purchased:
