Am in need for some DEC AP4U Relays for a Rotel RB-880 would like to buy some if available
You can use any reasonable relay, if you solder 2-3" long solid core wire to the contacts and put some shrink tube over them. Even if the orientation is different, there is no problem to cross the wires as needed. The relay will "fly" a bit over the PCB, but the solid cores will hold it in place for the next 50 years. It is a good idea to use a double relay parallel for each channel. One contact pair will hit first and take the switching load and burn, the other one will join later, stay clean and keep the resistance low. The often used one contact, one channel relays will always corrode from use and lead to distortion. Often even quite expensive amps have such a cheap loudspeaker relay that worsens sound over time. Maybe even wanted by the manufacturer. I always have a good look at the contacts on any amp I open up for service.
The last stage of this increasing problem are temporarily quitting channels and reduced output with distortions. This sometimes gets better by switching the amp on/off a few times.
Usually the footprint is standardized enough so you can choose a sub from Digikey or Mouser. Verify the coil voltage.
Also eBay seems to have a lot of DEC relays.
Are you certain the problem is the relay itself, and not excessive DC output, which should trigger the relay?
Measure the DC before the relay contacts and see.
Greetings again Guys would anyone know what a good substitute might be Relay for the IDEC AP4U 24 V attached are some pics
If there is a substitute, would I have to modify or cut any leads of the Substitute Relay is Resistance I measured is about 681 Ohms
Turns out this relay has four SPDT switches. The board connects all of the four in parallel for one higher current switch.
So all you need is a 10A or more relay with a 24VDC coil, with one or two SPDT switches, a standard configuration.
However you'll have to work out a way to connect it to the board, since the old footprint won't work any more.
Perhaps a local tech could do this for you.
I can't thank everyone who has been helping me Attached is the back of the PC Board any Insite as to how I could go about wiring a standard 24 Volt 10 Amp Relay in place of the old relay would be greatly appreciated
ok it's much clearer now, they chose this quadruple relay to pass more current but it's a double circuit, so a two-way relay that passes enough current can be put in place with almost no modification, just a bit of drilling and adaptation.
Maybe you don't want to read this, but if it is a 4-contact relay, I expect it to be perfectly fine.
The trick of multi contact relais at this position is not the 4 times as high allowed current. Inside such a relay the contacts never hit at the same time, some are always slower. You expect the fast ones to sacrifice contact condition to switching loads, while the others keep their as new condition and will conduct with lowest resistance for ages. So some contact will burn and build up corrosion, while the others don't.
Take a very good look at the contacts, you should see different signs of wear. Maybe just reinstall it. If you can open it, maybe use some contact cleaner, but never scrape or file the contacts.
I don't know what to think because I've never thought about it that way but it's a hypothesis that holds water.
On the other hand I totally agree that the relays probably don't have a problem, unless something else is damaged on the two PCBs.
In case, here is the relay couplet reference, you can find some... in China.
relay AP4U-24VDC:A6R-110-0​
Thank you, Guys, very much for your gifted insight concerning the Relays.
What you are saying makes sense hopefully If I can open them up and look closer, I might be ok if not there was someone from France
Who made the suggestion of using a 10 Amp Relay I believe a Dubble Pole Two Throw Relay and mentioned I might have to drill some holes in the PC Board
To accommodate the new Relay, I just don't know where to drill the holes in the PC Board.
Again, many thanks for all the time and consideration for helping me much appreciated.
