Difference in results between the QA403 software and REW
Hello,
I was making measurements of a system that I am building and I notice that I have two quite different results if I use the QA403 software or REW (via the ASIO drivers).
For the moment I do not understand the difference or where is the setting error.
Both included curves measure the same equipment. I just switch between the two softwares.
Has anyone already encountered this problem?
Stef.
