Filtering out distortion from a function generator
I haven't had good luck building physical sine wave generators. I want to make a fixed 60Hz sine wave generator.
Giving up on doing it myself, ebay has lots of boards with those out-of-production function generator ic's on them. But to do the distortion trim on them I would need instruments that I'd rather not buy.
It occurs to me, though, that if I follow the sine output of the chip with a regular opamp 12db/octave lowpass filter set at 60Hz, it would clean up a lot of the wave's distortion. Harmonic distortion is harmonics, right? If you filter out the harmonics you filter out the distortion, right?
I expect a lot of attitude from the ideaphobes here. It always happens. Knock yourselves out. If anyone has anything helpful or constructive or experience to share, that would be pretty keen.
There're many ways to clean-up a sine wave:
1) Resonant filters.
2) Sinewave shaping circuits.
3) Notch / comb harmonic filters.
4) Harmonic cancellation methods.
Each method has its advantages and also some disadvantages. Filtering the second harmonic using, say, a 12dB/ octave slope would give you much less than 12dB suppression.
My recommendation would be to use (4) that is, cancellation of selected harmonics using trignometric properties.
(Here) is a self contained quartz crystal controlled oscillator that runs at 6.000 Megahertz and has a frequency stability of ±100ppm. For USD 2.45 in quantity=1.
Connect the crystal oscillator's output to a digital frequency divider you've built out of counters and gates, which divides by one hundred thousand. Now you have a 60.00 Hertz square wave with a frequency stability of ±100ppm.
Put that 60.00 Hz square wave through a cascade of analog filters such as mentioned in post #3 above. Done. A frequency accurate, low drift, independent of AC mains, 60.00 Hertz sine wave.
The OP has not stated how low the distortion needs to be. The oscillators I am referring to have distortion lower than the THD wars.
Ed
Yeah, you're right. I saw somewhere that the standard for the power companies, which few of them meet, is two to five percent distortion. I'm going to use this oscillator to run a turntable. Those are the numbers I have to beat. I think that if I can get under one percent, I'll be fine.
I haven't seen much to dissuade me from the cranky old function generator and a low-pass filter. Oscillator circuits that I see strike me as a little unstable. I'm sure as heck not going to build a circuit board the size of a sheet of typewriter paper. This is not a Dreamland project.
