I received an email from diyaudiostore over the weekend that the F6 parts kit was back in stock, but while putting together an order the following day, the F6 kit disappeared from my cart and now appears to be out of stock again. Is that right, the F6 kit already sold out?
First rule of audio: you snooze, you lose...
I would try the link again. I just finished an F5M build so I will probably not order the F6 PCBs/kit. However, I just tried the link in the email after seeing your post and there appear to be kits still available for purchase.
Thanks, you might be right! Like I said, the F6 kit disappeared from my cart and then when I looked for it in the store, I couldn't find it... but I never thought to go back to the email and click through that link again. I did that after seeing your post, looks like it might actually be in stock, fingers crossed...
We did do a slight change to the product in the first few minutes which would have had that effect (removing it from your cart). There are still some left though if you access the link in your email. It's not currently available to be found via the navigation or search, just the direct email link.
