Speaker Protection in Parasound monoblocks JC1
My Stereo setup includes Rose 150B as streamer and preamp running via parasound JC1 monoblocks feeding Monitor Audio Platinum 300 tower speakers
2 days back I was listening to this setup for about 30 minutes. Midway I restarted my Rose150 B while the amps were already powered up.
I heard a spike in the speakers with small blast. The bass driver coils in both the speakers burnt. There are 2 base drivers in each speaker so 4 base drivers were damaged.
The problem more likely emanated from Rose 150b as it is unlikely that 2 independent amplifiers will develop same problem at the same time.
I can rule out the power supply issue as the system is being fed from a 5KVA APC UPS.
Has any one faced similar issue. What checks I need to perform before I restart my system
I also want to know if Parasound Jc1 monoblocks have speaker protection circuit or this is something I will have to mod.
I changed the speakers and the system works ok. So at present the damage is only to the drivers.
Any help will be appreciated.
